fwunder
- #16
Oh! Thanks! I should have read the manual. Doesn't appear I messed anything up that I can tell.If you connect directly to the negative post on the 12V battery, the battery management system (BMS) doesn't/can't "account for" the KW that were added to the battery.
It's a very sophisticated BMS, although there are plenty of questions about the logic that Ford is using. And a LOT of complaints about the charging logic that is hellbent keeping the AGM battery at a lower SOC than most would like.
Note that you saw a drop from 14.2V to 13.2
The BMS will lower the V more aggressively than many feel it should, which seems to inhibit the battery from being kept at a higher, say 85-90% SOC.
I digress.....
If you hook the negative terminal of your external power source "behind" the BMS sensor, then the BMS logic is accounting for that current.
Your owners manual even instructs to do so.
Point #1 or #2 is preferred.
I use #1 because it's easy to get the clamp on.
