Front Axle Seal Leak on Passenger Side
Overboost
Earth
Saturday I found a fairly large spot on my driveway. Upon further inspection, determined it to be coming from the front passenger side axle shaft. I occasionally use the 4A feature when the weather is bad, but have not used in over a week. Truck is a 2022 PB 502A with FX4.
Has anyone had experience with a similar issue? If so, what was the repair, and how long did it take?
Pictures of findings below:
Ford F-150 Front Axle Seal Leak on Passenger Side 20230204_102610
Ford F-150 Front Axle Seal Leak on Passenger Side 20230204_102527
Ford F-150 Front Axle Seal Leak on Passenger Side 20230204_102524
2mileshigh
2021 F150 Platinum PB - Antimatter Blue
Just found this through search. My 2021 is in the shop waiting on parts for the same issue. 5 days in the shop so far. It's been leaking for some time. 15K miles on the truck currently. Did you get your truck fixed?
Overboost
Earth
I did. Dropped it off at the dealer and had it back in a few days. So far, no leaks to report.
Chease44
Dan
Ontario
2021 F150 Lariat - Star White 3.5 Eco 157” WB
My truck is currently getting an IWE replacement and front pinion seal. I noticed in December while under my truck to pull off the transmission diaper that was dragging on the road, that there was oils on the crossmember directly under the front diff. Last oils change they did not notice oil leakage but today while diagnosing the IWE issue they confirmed that the front pinion seal was toast. They had that in stock and hopefully I’ll have my truck back tomorrow.
