Driver side window won’t go down all the way
hammer40
Vashon Island, WA
2022 Ford F-150 Tremor, 1970 F250
Business owner
Does anyone have an issue where the drivers side window won’t go all the way down? Mine is about 2” from going all the way. Passenger side is fine.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Have you tried resetting the window? Hold the button down for 10 seconds and then up for 10 seconds...relearns the settings. The window should be OK...
Ford Motor Company
Official Ford Account
Ford
Dearborn
Good morning. Are you still experiencing this concern with your drivers side window? If so, I would like to look into it on my end. Please send over a private message with your VIN and the name/location of your local Ford dealer.
Buddy
Buddy
St. Peters, MO
2021 F150 King Ranch, 2020 Lincoln Aviator
Retired Veteran
As I told DougMuster - Call your local dealer and they can talk you through the reset over the phone. At least, my dealer did when it happened to me. If I remember correctly, you lower the window down holding down on the button about 3 seconds after it goes to the bottom. Then, do the same raising it (not on auto - hold the button up) and hold the button about 3 seconds after reaching the top. Do that sequence 3 times and it will reset itself. It worked for me when I had window problems and also for DougMuster
Graygoose2021
Oklahoma
Sales
Reset video
hammer40
hammer40
Vashon Island, WA
Business owner
I have. I‘ve had the bounce back issue since new and reset many times. I cannot get the window tight to the top without bouncing back.
Graygoose2021
Oklahoma
Sales
Mine did it, replaced the battery about a year ago...no issues since. its a safety issue to keep you from getting locked outside truck.
hammer40
hammer40
Vashon Island, WA
Business owner
PM Sent
hammer40
hammer40
Vashon Island, WA
Business owner
I cannot hold it in the up position. No matter how much I baby it up there, it bounces back.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Kanuck
Winnipeg, Manitoba
Retired Electrician
S
No, I have not tried replacing the battery. I can't imagine it's keeping the window from retracting the last two inches though.
Sorry..I ment the video
Gskoons
George
Virginia Beach
2023 F150 Lariat Hybrid Powerboost
Carpenter
My window stopped working. I took it in and there was a tub for the driver side switch. Swapped it out no issues.
2Lazy2P
PNW
Il Dolce Far Niente
I’m having the same issue with the front passenger window. Does not go down all the way. When it goes up it’ll bounce back.
