Double-Honk When Door Closed While Truck Is On
Los150
Carlos
2023 3.5L EB Platinum w/BAP
Info Tech
you need forscan. I see your from USA with a king Ranch, you will be amazed at your headlights if you use forscan to turn on glare free :)
and once you turn off the double beep, you will still hear the mild ring from the radio when you close the door and have fob in your pocket, so the protection is still there.
Which one is the "glare free" and is that available on the Platty?
