Does using FORScan affect ability to receive OTA software updates?
zacko11288
Illinois
2021 F150 Lariet
Engineering
If you make a modification to your vehicle with FORScan (like turning off double honk) does that impact your ability to receive OTA updates? If you do get updates OTA,or from dealer will that revert changes you've made?
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
It shouldn't impact the ability to receive OTA updates. Certain changes could be overwritten, depending on the update. Most should persist through updates though.
The only thing I have had revert during an update thus far is APIM coding for the IOD cards on the side of the 12" display. The one update changed configuration to add the bed camera card, so my changes to add/remove them were undone. I haven't had anything else revert that I've noticed.
Tharnett78
Todd
Edmonton, Alberta, Canada
2022 F150 Powerboost, 2008 F150
Gas Plant Operator
What did you change in the APIM for the cards? Did you remove them? Did android auto go full screen?
zacko11288
zacko11288
Illinois
2021 F150 Lariet
Engineering
Tharnett78
Todd
Gas Plant Operator
When's this supposed to roll out?
imnuts
Dirty Jerz
Facilities Engineer
I disabled cards I didn't want and turned on the two off-road cards.
Tharnett78
Todd
Gas Plant Operator
Ahh, ok.
