Dash Cam (fuse-tap) for 2024 Ford F-150s
Nightshade
AJ
Alberta, Canada
Anyone with a 2024 Ford F-150 figure out which fuses to tap (dual fuse taps) for constant and ignition fuses? On my 21 and 22, was able to use fuse slots number 2 and 4 but this isn't the case for 24s since they changed the fuse box again. Doing the hardwire route because I want to be able to leave the dash cam on for parking/sentry mode.
Was considering using the amplifier fuse for ignition and wireless charger fuse for constant but not sure yet.
Would love to get an input and see what other 24 F-150 owners have done to achieve this.
Interior Fuse Box Diagram - '24 F-150
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
Mine runs through the odb port dongle
It allows camera to run 24 7 if needed
But does require running the harness across front under headliner, then down a pillar
Nightshade
Nightshade
AJ
Alberta, Canada
Will be considering this as a last resort if needed; that’s a really good idea! Will need to order in a OBD splitter from AMP because I have the AMP Xtreme power running boards in that port right now. Routing shouldn’t be an issue, long as I have the 2 features active!
powerboatr
Amazon and a few others have a odb splitter dongle
That gives you a free open port for forscsn or ?? Plus ppwer up the accessory
Ford F-150 Dash Cam (fuse-tap) for 2024 Ford F-150s Screenshot_20240924_100720_Chrom
Nightshade
Nightshade
AJ
Alberta, Canada
Yes sir, those are where I’ll be looking and ordering one in later today! Thanks for the idea!
