Hey folks
just picked up a 21 xlt. The truck came from Canada and anytime a make an ipc change or really randomly it’ll revert back to km and Celsius. Anyone know if a way to make it default to the US so it stops doing that?
thanks for any help
Take a look at:Not sure. My buddy also has a Canadian truck that’s here in Michigan. 18 XLT. When I use forscan to change things in his truck it does the same thing and we have to change it back. Not a huge deal but I agree would be nice to have it default to US.
| 720-04-02 | xxxx | *x-- |
UPdate:I took a peak today and i actually have a 9 in there and confirmed on my motorcraft service as built data that a 9 is correct from ford.
I'll try a 0 nd see what happens
Try this:UPdate:
The 0 seemed to have no effect so i put the 9 back in there and will try to find a US build with the same options to compare
You were correct.Try this:
US (Blue) vs. Canadian (Green)
First 4 characters are the country code. 5th is the unit selection.
Changing all 5 might work for you.
Well fellas, No dice. I even changed the country code in the APIM thinking because that's where you change the units maybe something was conflicting.You were correct.
He needs to make it 5553 12XX
It may take a reset of the IPC after the change
I’ve changed anything and everything that has to do with country in the ipc, apim, and ipdm (the camera one) and none of it helped.I am in the same boat. Looking to convert my Canadian truck to USA (moved). I do have access to FORSCAN and a similarly optioned US 2022 Lariat a co-worker owns, if someone wants to tell me what I'm looking for...
