- First Name
- Adam
- Joined
- Feb 15, 2022
- Threads
- 86
- Messages
- 276
- Reaction score
- 172
- Location
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- Vehicles
- 2018 Raptor & 2021 Bronco Outer Banks
- Occupation
- Drug Dealer of the LED World
If you're looking lighting setup that's hidden behind your grill then this is the kit for you! This bolt-on kit allows you to run 6x lights behind the grill of your F-150, giving you a tremendous amount of light down range. The include KR Off-Road brackets are made from stainless steel here in the USA (and powder coated black) and allow you to mount your lights in a variety of ways. The mounting channels on the KR Off-Road brackets ensure you can install the lights in a variety of ways. If you prefer to keep the lights lower in the grill, you got it! Maybe you want the lights up higher, no problem. The vertical alignment channels allow for this flexibility.
We also make wiring easy with the included CrystaLux wiring harness. This harness has 6x Weatherpack connectors on it that plug directly into the lights. The other end of the harness has 3 wires (plus a ground) that you can wire to an existing upfitter switch (or switch panel). Each pair of lights can operate independently on it's own switch allowing you to turn on lights for whatever the road condition is ahead of you. If your truck doesn't have auxiliary switches, no problem. We've included 3 switched harnesses as well which include relays and rocker switches allowing you to mount the switches on your dash board.
INCLUDES:
- 1x Pair of KR Off-Road Brackets
- 3x Pairs of Lights (or 2x Light Bars)
- 1x CrystaLux Wiring Harness (for OEM auxiliary switches or aftermarket switch panels)
- Mounting Hardware
- Instructions
- Our Lifetime Guarantee. For as long as you own your F150, if you manage to break/bend/destroy the KR Off-Road brackets we'll replace them free of charge (not including return shipping)
- 2015+ Ford F-150 (including Raptor and ALL trim levels)
Available Here: https://www.4x4truckleds.com/shop-all/kr-off-road-behind-the-grill-kit/
