Have an alert in my ford pass app saying it detected an ABS fault and the abs is disabled. ‘21 XLT. Is there a way to verify this at the vehicle. I’ve tested the brakes by stepping on them at 30mph and they seem to work fine.
You could check and see if you have any DTC's stored in your truck to confirm what happened. You would need a ODB scan tool such as the ODBmx+ that can be purchased on Amazon for about $135.00. This will connect with Bluetooth to your phone and allow you to scan your truck and see what's going on. This tool will tell you many other things about your truck as well.
