It's done with Forscan software. Alot of threads on it and even has its own Forum too. Google Forscan and read tons of threads about it. Kinda neat what you can doWhere can I find out more about all of this moding your dash? I would luv to be able to mod my 2021 F150 FX4!
Mine is a 501A as well, but 21. In your picture, the line in question says 8EA0 in the second block, but should be 8E503.5 Ecoboost and trailer brake controller. It's a 2022 501A package
Unless I’m crazy your image shows “EA”. If you change that A to a 5 it should work. 720-07-01 xxxx xx5x xx. Or was that A a test after trying 5?Has anyone successfully enabled the temp readouts under the gauges in the 12" all digital Lariat screen in a 2022? Using the Forscan spreadsheet .....mine already has the xE5x from factory but no temp readouts. What am i missing? Line 720-07-01
Hello,Where can I find out more about all of this moding your dash? I would luv to be able to mod my 2021 F150 FX4!
With the turbo and the brake controller it is E5. I am trying to get this to work on my XLT but no go yet. It is a 2022 Powerboost with the brake controller E5 doesn't seem to work.Unless I’m crazy your image shows “EA”. If you change that A to a 5 it should work. 720-07-01 xxxx xx5x xx. Or was that A a test after trying 5?
This only works on the Lariat+ 12" cluster.I am trying to get this to work on my XLT but no go yet.
Thanks for the reply really appreciate thatThis only works on the Lariat+ 12" cluster.
Nope. There are some lines in the config for it, but it's for the Raptor IPC.I have changed the temp read outs, what about the oil pressure?
