35x12.5 on 18’s???
Tmacc
Tyler
Philadelphia, PA
2023 f150 xlt
Getting a 2023 xlt soon. Will 35x12.5 fit with a 4 inch lift? Does anyone run these tires on 18s? Trying to figure out what set up I’m going to go with and what I’ll need to do to run 35x12.5 Thank you
NotMyName
John Doe
2021 Bronco First Edition, 2022 F150 Platinum Powerboost 4x4 CCD
I would personally go with 17” wheel so that I could get the Raptor size 315/70r17 C2, BFG K02. They’re the only C rated 35” (technically 34.4” x 12.4”) tire available that size under a D rating. Specifically made for the Raptor, they are much softer and lighter than D or E rated tires. Softer sidewall means better ride. Lighter weight means less power needed and higher mpg. The last type of weight you want to add to any vehicle is Unsprung weight.
Graygoose2021
Oklahoma
Sales
Stick with a + offset, i did +20 on mine, stockers are +44.
Ford F-150 35x12.5 on 18’s??? 20230917_160303_resized
9663mu
Chad
Agoura Hills , Ca
2024 Powerboost 157
It should fit but like above said it will also depend on your Wheel Offset .
Are you going FULL BRODOZER like super negative offset ? :)
Tmacc
Tyler
Philadelphia, PA
2023 f150 xlt
Thanks for the info!
no I just wanted like a little poke. Nothing real crazy. I also don’t want to chop up my brand new truck to make them fit
Graygoose2021
Oklahoma
Sales
Keep as much + as you can
Graygoose2021
Oklahoma
Sales
That looks good. Did you have to do any cutting and what kind of lift. 4 inch?
thank you, no, just a level. Rear is OEM stock.
I did trim my front crashbar, just slightly, reverse on full turn, it rubbed one side, just a little
DeuceRooster
Dustin
Kentucky
2023 F150
Sales
I am running 295/70/18 on mine with an 18x9 (zero offset) wheel. the tires are 34.6” and I still had to do some minor trimming of the front bumper.
Ford F-150 35x12.5 on 18’s??? IMG_5741
gregs150xlt
Tennessee
2023 Ford F150 XLT
These are 35x12.50s on stock 18 inch wheels. 2 inch level and 1/8 inch wheel spacers. No rubbing. Hope it helps!
Nice truck!!!!! You don't see too many regular cabs these days. Looks awesome!!!
