I have a (probably irrational) fear of messing up my truck’s computer so I did not want to use ForScan. Instead I got and installed the Hypertech in line Speedometer correction module. Worked well for me but most will use ForScan.
Just did it a few days ago. Not too difficult in forscan. What you will need is the circumference of the new tires. After reading the manufactures site I used Michelin’s numbers for circumference but the speedo and the GPS were not matching so I did it the old fashion way with math. Still not match the GPS. The final time I took a ride with forscan connected and decreased the circumference by 10mm each time until I got it spot on with the GPS. I used Waze on my CarPlay which made it easy. So, if Waze GPS is off then so is my truck but i got them to match up exactly.
By the way the circumference is measured in (mm). I believe i ended up 50 mm under what Michelin’s chart said.
So,..
If I change out my OEM tires and put on the 35x10.5 R17's will it be drivable until I can get the Forscan / speedo re calibrated, or will there be drivability issues and error codes ?
