Stage3Motorsports
Arizona
2021 F150 STX CrewCab 4x4
Shop Stage 3 Motorsports for all your audio needs!
Kicker Upgrade
Looking to take your F-150’s sound system to the next level? Our Kicker Plug-and-Play Speaker Package delivers crisp highs, deep bass, and an overall richer audio experience—all with an easy, no-splice installation.
  • Plug-and-Play Installation – No cutting, no splicing, just better sound
  • Crystal Clear Audio – Hear every detail of your music like never before
  • Designed for 2015-2025 F-150s – A perfect fit for your truck
  • Proven Performance – Trusted Kicker quality, engineered for Ford
Easy Install!
Ford F-150 🤘🔊 Don't Settle for Weak Factory Speakers - Kicker Upgrade NOW! At Stage3motorsports.com In%20Plug-and-Play%20Door%20Speaker%20Package%2000
Ford F-150 🤘🔊 Don't Settle for Weak Factory Speakers - Kicker Upgrade NOW! At Stage3motorsports.com 1741453894724-6x
Subscribe to our newsletter for a little extra Savings! ?
Stage3Motorsports
Stage3Motorsports
Arizona
I did this upgraded speakers on my truck. Greatly improved the sound.
That’s awesome! A good speaker upgrade can really transform the sound quality. Which ones did you go with?
Ricksc
Rick
Bay area
I went with Kickers DS 6x9 3 way in the front and 6.5 in the rear.
Cooder_Graw
Atlanta Georgia
2022 PowerBoost 4x4
Kicker Upgrade
  • Designed for 2015-2024 F-150s – A perfect fit for your truck
Easy Install!
How about a plug and play subwoofer?
Stage3Motorsports
Stage3Motorsports
Arizona
OH, we have those too!
If you're looking for a compact subwoofer solution, Kicker's Hideaway speakers are a great choice. We offer both 8-inch and 10-inch options, designed to fit under seats or in other tight spaces while still delivering solid bass performance.
Ford F-150 🤘🔊 Don't Settle for Weak Factory Speakers - Kicker Upgrade NOW! At Stage3motorsports.com 1741472481458-1v
Ford F-150 🤘🔊 Don't Settle for Weak Factory Speakers - Kicker Upgrade NOW! At Stage3motorsports.com 1741472556005-d
Shop both here!
Both sizes come with a built-in amplifier, making installation easier without needing an external amp. If you're after deep, punchy bass in a discreet setup, these are definitely worth considering! Let us know if you have any questions—we’re happy to help.
Ricksc
Rick
Bay area
What would you say improved with it? Could you give a quick review as I'm interested in this but not sure how much it would change the sound.
These speakers increased quality of the sound. The 3 ways you can hear the bass. I could barely hear the rear speakers with fade set to 80% to the rear. After the installation of the speakers I can hear the rears. Stock speakers had a 1 inch magnet. These have a 3 inch magnet. I was surprised at how much better the sound was.
Stage3Motorsports
Stage3Motorsports
Arizona
Any info on installation with the B&O system with the crap amp? Speakers were simple.
Yeah, the speakers are an easy swap, but the B&O system’s amp can be a bottleneck. Some people add a DSP or aftermarket amp to get the most out of the upgrade.
An amplifier (amp) boosts the power of an audio signal, allowing your speakers to play louder and clearer without distortion. In a vehicle audio system, the amp takes the low-power signal from the head unit (stereo) and increases its strength before sending it to your speakers or subwoofer, ensuring cleaner sound and better performance.
A DSP (Digital Signal Processor) takes things a step further by fine-tuning and optimizing your audio system. It allows for precise frequency adjustments, time alignment, and crossover control, giving you the best possible sound quality.
For Ford trucks with the B&O system, the factory amp can be a major bottleneck, limiting the performance of upgraded speakers. Adding a DSP helps clean up the signal and improve clarity without replacing the amp. For even better results, pairing it with an aftermarket amp unlocks the full potential of your audio system, delivering stronger output and more detailed sound.
We are in the process of receiving the amps and posting for sale. When we receive them I will link it here!
Bucknut22
Jimmy
South carolina
2023 Tremor
When you talk about the b&o system, are you also referring to the upgraded "unleashed" system. I'm just curious how much of an improvement these speakers and DSP provide over the upgraded system or if you're mainly referring to the base system (I believe 8 speaker?)
Thank you!
Abraham5G
Abraham
Houston, TX
Is this a good upgrade for the B&O Unleashed system? Would you suggest amplifying the rear door speakers?
hardiharhard
Matt
NE Florida
'24 STX 4x4
Do the stock base speakers ('24 STX) have the same amp bottleneck as the B&O? Thinking of doing the door speakers but not interested if it won't be noticeable. Not a speaker head here so forgive my ignorance!
GR8BBQ
Aaron
Hamlin, New York
2024 F-150 XLT Super Crew Avalanche BAP
Shop both here!
So if I buy these from you they are "plug and play?". I don't have to run new wiring? We are looking for plug and play subwoofers, that was the ask.
