Can I add fog lights to my '22 XL screw? Mine did not come with any, there are plastic inserts in the place where they go. I was planning on buying the diode dynamics ones in april when they are available. Is it even possible to install them?
You can easily make them work as oem. You either run a wire to your body module and then add it in forscan or wire it into your low beams. I think the problem is installing the oem led with drl. Those will not have factory function because of the drl. The halegon trucks don’t have a drl power source.
