2022 F-150 Powerboost Rear end Failure
Cdrose1966
Dwayne
Hammond, La
2022 f-150 power boost Lariat
Electrican
At 17,000 miles major part in transmission had to be replaced due to leaking transmission 1st reported to dealer on 1/28/23 work completed 5/26/23.
33,000 miles rear end made loud clunk then started making grinding noise truck won't move unless in 4WD. It's being towed to dealer now. Has any one else had this problem?
Hrm, just last week there was another report of a grenaded rear end using 4wd to limp. Is this a max tow equipped truck?
Cdrose1966
Dwayne
Hammond, La
Electrican
Yes it's a max tow.
Could have been the floating axle bolt issue causing the axle to slide in and strip the little bit remaining in the splines. Curious to see the cause. We've seen both pinion damage and the axle slide in on max tow.
CoolCoyote
Jefferson
Detroit
2020 Fusion
Pop some popcorn and research Max Tow axle bolt failure.
Airborne_Ape
Chad
Atlantic Canada
2010, 2014, 2017, 2021 F150
:unsure: Having a rear diff grenade itself is not the same as the incorrect rear axel bolt thread pitch recall, but I’m curious if he had the recall done already and someone messed up when they replaced the half shafts.
I'd sure like to hear his vocal representation of the noise, but it could have been the pinon / ring gear, but I'd believe it's the axle sliding in, splines lack sufficient engagement, splines get sheared, diff just spins. Not a grenade scenario, can be checked by engaging locker (only after stopped) and seeing if motion possible.
Last weak was a failed pinion / ring gear. Instance before that was max tow axle sliding in and stripping.
