I would do all fluids. Doesn’t matter how many miles. It also goes off of years.I changed the rear differential fluid around 70k miles. Front hardly gets used correct?
transmission service?
While it gets used less often, I would still service it when I service the rear differential.I changed the rear differential fluid around 70k miles. Front hardly gets used correct?
Should be doing that every ~40K miles or so, regardless of what Ford "recommends". Unless you don't mind putting a new transmission in.transmission service?
